- Jan 11, 2007
- 789
- 0
- 71
recently I've been using a ton of AA batteries, from my battery eating camera to my xbox360 controllers. What kind should i get, and i notice some have different mv(millivolt)s. what kind should i get?
Originally posted by: Doclife
I recommend that you get the low discharging NiMH rechargeable batteries. Basically, with the low discharging type, once you charged up the battery, the battery will retain about 85% of the charge after 1 year of storage (very convenience and ideal for use in TV/DVD remote controller). Regular NiMH rechargeable batteries will self discharge to 0% after a month or so, whether you use it or not.
The low discharging type I use is Eneloop, made by Sanyo.
http://thomasdistributing.com/...130dbb9c5e50d2bff55c21
The charger I use is the Maha 401FS with the 100-240VAC adapter. I like this charger because I have the option to charge the battery from 0 to full in 100min for emergency or the 5hr slow charge to prolong the battery life. The other thing I like about this charger is that I can use it anywhere in the world with the included 100-240VAC adapter.
Are you sure they discharge that quickly? I only had to recharge my Ti-89 batteries last night. I recall using them through finals last semester. I recharge maybe once a semester usually.
