Originally posted by: purbeast0
Originally posted by: Aharami
i have a workout question as well. instead of making a new thread, i'll post my question here.
I usually weight train for like 2-2.5 hrs and then run for 30 mins. two days ago i weighed myself (with just boxers and shirt on) before running and I was at 153.2lbs. after running, with the same clothes on, i weighed 151.2lbs.
found this curious, so i repeated this experiment yesterday also. before running, I was 154.4lbs, and after I was 152.5lbs.
Now, is this normal? losing that much water-weight from just 30 mins of cardio? I am assuming its water weight i lost.
you are REALLY REALLY overtraining in the weight lifting department. your weight lifting exercising should not go more than an hour. more than an hour is too long. you should target 45mins if possible. i realize that if you are working out with a partner it will take longer, but if you are by yourself, it should never go past 1 hour for weight training in one session. after that, you are just doing overkill. your body is just physically too exhausted to push yourself to your potential.
if you don't believe that last statement, just try splitting your 2hour workout into 2 1hour workouts. i guarantee you that on your 2nd day you will have more energy/strength than you would have had your 2nd hour of the normal workout routine.
but losing that much water weight is pretty normal, if you are a sweater. i personally sweat a LOT when doing cardio. hell, i sweat a lot when lifting weights. i typically can vary in weight by like 3-4lbs each day, depending on which time of the day I weigh myself. i wouldn't worry if i were you about that water weight.
and fyi, running hard for 15 minutes is better for you than jogging for 30 minutes. that crap you see on the treadmills that say to target a lower heart rate for fat burn and a higher heart rate for cardio misleads people. in general, the higher your heartrate, the more fat you are going to burn. and to get your heart rate up, you have to do high intensity running. if you jog for 30 minutes, you probably won't get your heart rate anywhere near the target cardio (which is what you want for the best results).
i am 23yrs old about 182-185lbs right now, and when i do lower intensity cardio my heartrate is about 120-130bpm. if i do high intensity it is between 155-165bpm. from my experience, i have always seen the best results from doing thie higher intensity with my heartrate up the whole time. i tend to run after i lift weights as well because lifting will get your blood flowing and your heart rate up as well.
