Hello,
I have built a few computers in my time, but a few things elude me.. Please help if you can..
1. On motherboards, the holes that are used to secure the mobo to the case, do you need to use them all (i.e do they offer ground protection etc..) If there are 10 screw holes, I need to use all 10?
2. The pin headers that the reset button, power button, led activity etc. connect to can go on one way or the other (ie. one way, or flip it 180 and it can also go on) Does that matter which way. Or if it was the wrong way, would the buttons not work?
Thanks a lot
Thanks a lot
