few mobile cpu questions
Snakexor
what pin configuration is yonah, and if it is 479, will it work in a shuttle config that is designed for P-M? if it is 775, will it work in one of those?
what pin configuration are the new dual core turion chips and if 754, will they work in the 754 pin shuttle?
final question is, will shuttle come out with a 754/pci-e model?
ultimately i want to build a SFF with a shuttle barebone using a mobile chip and pci-e, if possible
Google is ur friend first off. This came from the second result...
"The Yonah socket is still a 479-pin interface, however the pin-out has been changed once more, and of course Yonah won?t even physically fit into any current Pentium M motherboards. Instead, you?ll need a brand new motherboard with a brand new chipset. So if you invested in any of the handful of desktop Pentium M motherboards that were released over the past year, you?re unfortunately out of luck."
Whole article here.
Will G.
