Originally posted by: Born2bwire
Originally posted by: chuckywang
I don't think the "d" in the equation is the same "d" in the problem. Can you elaborate on what the "d" in the equation is?
d appears to be the distance of separation between the physical charges that make up the dipole. The P in his equation should be the dipole moment, which for an electric dipole is q*d. The field for a dipole moment is given by:
\vec{E} = p/(4\pi\epsilon_0r^3)(2\cos(\theta)\vec{r}+\sin(\theta)\vec{theta})
which reduces to his equation 22-8 when you substitute in theta = 0 to find the z directed field along the z axis.
A dipole, or any multipole, is the superposition of multiple static charges (at least in the case of our electrostatic problem). So the exact field is simply the summation of the electric fields resulting from your sources. In this case it is the two fields that arise from the positive and negative charges that make up your dipole. So it is as simple as just finding the coulombic field that arises from your static sources.
For small separation d's, the far-field case of a multipole can be very closely approximated using the dipole moment, that is, you degenerate the case into a single point source as opposed to the superposition of multiple point sources. In this case, you see that even at the very close distance of 6 times the separation of the charges, you only have a percent error of 1.3%. In addition, we see that we can better approximate the behavior of a physical dipole using a pure dipole by either reducing the separation of the source charges or by increasing the distance of the observer.
