Since ivy and haswell are deliddable, I was wondering if it would be feasible to use a direct touch heatpipe heatsink (like the h212 evo) and directly mount it onto a bare die with clu. The hyper 212 specifically because the heatpipes don't have the huge multiple gaps between them. I know there are still small grooves between the heatpipes but maybe it would be possible to lap them away or something? Maybe mounting the heatsink so that the heatpipes are orientated perpendicular to the long ivy/haswell die would make it so that all 4 pipes are able to directly contact the die? Has anyone even done this?
My reason being that since direct contact heatpipes are more efficient at absorbing heat, maybe this would work well with haswells/ivys concentrated thermal output. More of a how fast can you wick the heat away from a certain spot then how much heat can you dissipate in general... idk...just floating round ideas here. Also I'm not to keen on watercooling and the idea of mounting a killogram heatsink on a bare cpu doesn't inspire the most confidence, especially since I live around 20 miles from the san andreas fault...D:
