FC-PGA and PPGA Celeron questions !!!
PCvas
my motherboard says to support Celeron PPGA 433-633 and up at 66 MHZ FSB and Pentium III FC-PGA 450-950 at 100/133. now my question is, if i get a 566 celeron which is a FC-PGA, would it work on this motherboard, or will i have problems because it only supports PPGA Celerons? Also, the jumper settings for 66mhz cut off at 533......what should i do?? Should i go with Celeron 500 or 533 instead?//
PLEASE HELP!!!!!!!!!!!!!
Both the 533a and the 566 are great overclockers. Forget the 500. It's based on the old core.
