Originally posted by: TheAudit
I never liked the way gel flakes so I've been using conditioner as gel for many years now. I just "set" it when it's wet with a little conditioner and it "holds" just like gel would. Pick the right conditioner and it won't flake.
I've done this before when I ran out of gel but never considered it a permanent solution. I equate it with using soap instead of shaving cream. Which conditioner do you use?
yep, i use #1, and it costs like $12.50 for a 5oz. container (dont know the exact size, just estimating)Originally posted by: simms
1) Best hold is Joico ICE Spiker. HARDEST GEL EVER.
2) I've used Tigi Bedhead, not bad. It's pretty cheap too. BTW all these are hardcore, you need to go to salons to get them - or you can also get STIFF $(&*... but that's only here. you can probably pick them all up at your local drugstore.![]()
