leapingfrog0
A person in town called me to check out their computer that won't power on for them anymore. Nothing happens when you push the power button on the case. I immediately assumed that the power supply was dead, but to be sure that it's not something else, I took a peek inside the case to look at the LED connections on the mobo. Everything seems fine. Nothing got disconnected.
After that, I moved on to checking out the power supply. I flipped the switch on the back of the power supply to Off position for a few seconds, and then switched it back on to give the system some juice to see if anything would happen. When I did that, I saw the CPU fan jump several times and stop. When it jumps, the fan acts like it wants to move, but it can't. It's acts like it's stuck (which it isn't). It's like it doesn't have enough juice. A few seconds after the fan stopped jumping, I smelt burning circuitry.
I cannot see any burnt circuits or any other damage inside the computer. I can just smell it.
I told them they would probably need a new power supply and that I'd order a new one for them and install it, but before I do, I want to make sure that that's the problem.
Do you think the PS is dead, or do you think it could possibly be something else?
Thanks,
Andrew
Thanks,
Andrew
