Fatal BSOD Please Help!
iSwim100
Ok so I've been getting occasional BSOD's with the 124 error. I'm new to using WinDbg and after analyzing two dump files I believe that I have a faulty processor (I've owned this one since Black Friday and this problem has only recently started to occur).
It should be noted that everything is at stock settings: XMP is disabled, and all of my drivers are up to date now (at the time of the crash the integrated graphics driver was outdated, but I check for new drivers about once a week so it wasn't that old).
System Specs:
OS - Windows 8.1 Pro 64 Bit
CPU - Intel Core i7 4770k CPU @3.50 GHz
RAM - Crucial Ballistix Sport 8GB DDR3 1600 2x4
PSU - Corsair TX 650M
SSD - Samsung 840 EVO 120 GB
HDD - WD Caviar Blue 1TB 7200RPM
MOBO - Gigabyte GA-Z87X-UD4H running the latest BIOS version F9
GPU - Integrated graphics
dropbox link to dump files here:
https://www.dropbox.com/sh/bn8vmyevstnzbgb/zqCZ-9aRsf
I've run prime95 to check my CPU load temps and got these:
I have also ran memtest86+ for 5 passes with no errors.
I'm getting increasingly worried that this is a problem with my CPU.
Lastly, the error has occurred more times than the dump files provided, those just happened to be the only ones that I could find. Both of those crashes in particular occurred while using Google Talk and playing League of Legends. It should be noted that the same error has occurred while just surfing the web too.
Any help will be appreciated!!!
Ketchup
14,559
248
I ran your dump files and they are pointing to a driver, but it doesn't get much more specific than that.
That is, until I looked at your most recent one: WHEA_UNCORRECTABLE_ERROR
Hmm, how recently did the crashing start?
BTW, for a Haswell i7, you temps look perfectly fine, so I don't think it's a temp issue unless it has gotten much hotter. I might also think some graphical glitches if caused bu the CPU, since that is what you are using for video.
Is there any hardware using a driver, outside of the specs you have listed? What kinds of things is the computer doing when these occur?
