fastest video card without cooling fan?
Legoman2
I want to buy a new video card that is silent. I have a radeon 8500LE and unplugged the fan. The card works just fine. Is there another video card that is faster and only requires a heat sink. Perhaps a video card that the fan can be disabled and not burn out the GPU.
I know there are 9700's that have passive zalmann heatpipes. There might also be 9800's. If not though, you can still buy the heatpipe seperately and install it yourself. I can't think of any card that performs better than an 8500 where you can simply unplug the fan though.
Originally posted by: keysplayr2003
I believe the 9600 non pro is passive cooled.
That 9600 would probably perform around the level of his current card, perhaps even a bit lower. But yes, they are passive cooled.
It's usually cheaper to just get a fast card such as the 9800, and install the Zalman heatpipe cooling set yourself, as long as you can do it properly.
