Extremely unlikely. I don't see anything in the manual specifying what kind of power output that port can do, but it's essentially guaranteed that it won't do any of the variety of quick charging standards. Quick Google suggests the Note 9 supports both QC 2.0 and USB PD. Not to mention the phone itself won't do anywhere near 60W much less 100W.
Get yourself a USB PD charger and don't charge stuff off your PC. A PC is never the right answer these days:
Note 10+ apparently supports 45W USB PD. I would grab something like this:
Viper GTS
feel like this guy asks the same questions over and over! like is my toshiba xg4 good enough or should i get a new nvme! you could put that xg4 in a external usb c case and use your usb c port! daz what i use mine for!!!!!!!!!! you got pranked viper!!!!!!!! heheI'm going to assume that's a serious question, but I am deeply conflicted on whether or not you're screwing with me.
Data, of course. USB 3.1 Gen 2 is capable of 10Gb/s which means seriously fast external storage, external GPUs (on TB3), etc. The USB C port in all its forms is the fastest way to get data in and out of PCs that don't belong in a datacenter.
Example (900 MB/s SSD):
Pro Elite USB 3.1 Gen 2 Type-C Portable SSD
The Pro Elite USB 3.1 Gen 2 Type-C Portable SSD is the next generation in mobile storage, boasting not only increased storage capacity, but also exceptional performance. It’s designed to be a mobile storage solution superior to previous generations of USB-A portable SSD’s, as well as traditional...www.pny.com
Viper GTS
Bro r u ok?feel like this guy asks the same questions over and over! like is my toshiba xg4 good enough or should i get a new nvme! you could put that xg4 in a external usb c case and use your usb c port! daz what i use mine for!!!!!!!!!! you got pranked viper!!!!!!!! hehe
upgrade to a note 20! the note 10 is so old ;P
Yep i realized that the Note 9 supports only up to 25W of charging. I'm currently using the Google 15W PD charger and can get up to 2770mA (Ampere) I wonder if a 25W/30 charger will get me higher?Extremely unlikely. I don't see anything in the manual specifying what kind of power output that port can do, but it's essentially guaranteed that it won't do any of the variety of quick charging standards. Quick Google suggests the Note 9 supports both QC 2.0 and USB PD. Not to mention the phone itself won't do anywhere near 60W much less 100W.
Viper GTS
