I am currently looking for the fastest USB 3.0 expansion card to place in my old GIGABYTE GAEP45UD3R motherboard. From my research it seems that NEC and Fresco chipsets are the main contenders. The problem is most of the chipsets are very old. A lot of the cards use the NEC uPD720201 chipset. An example of a card using this is the Inateck KT4007. I believe this chipset was released in 2012, however it seems a very popular option even on recently manufactured cards.
The only later chipset I could find by NEC is the µPD720202 (not sure of exact release date), but not many cards seem to use this. Here is one example:
https://www.amazon.com/Express-Adap...UTF8&qid=1479209682&sr=1-3&keywords=uPD720202
Does anyone know how this performs compared to the uPD720201?
Out of all the manufacturers, the newest chipset I can find on a card is the Fresco FL1100SX which I believe was released in 2014. The Inateck KT4006 is an example of a card that uses this. From what I understand the Fresco chipset may not have as much native OS driver support, however It may have the edge in terms of speed. I also read that the Inateck cards using the Fresco chipsets, use higher quality capacitors etc. What are peoples view on this? Does Fresco have the speed edge?
Are there any other serious contenders? Through my testing I have not been very impressed with VIA based cards, such as the Transcend TS-PDU3.
