FASTEST P3 WITH 100MHz FSB?
Ulubula
28
Have a 810 chipset Mobo that ain't gonna go above 100MHz. Supports both Slot1 & Socket 370. Are Intel still increasing the speeds of their P3's that run @ 100MHz? If so, can you speculate what speed they're likely to top out at?
(Yes, I know I should go buy a new 133MHz Mobo and an Athlon, but if I just want a new CPU this is the simplest route, and I'm just curious to know where the 100Mhz P3 will end up)
BA
5,004
There GHz 100FSB P3s, but good luck finding one. But really, why would you put that on an 810?
John
Moderator Emeritus<br>Elite Member
I saw someone selling one in the f/s forum not too long ago.
Rand
11,071
As the others said there is a 1GHz P3 using the 100MHz FSB, besides that the fastest 100MHz FSB P3 is the 850MHz P3.
