Fastest Mini USB Flash Drive.
SSSMan
I got PNY 32GB Micro Metal Attache USB 2.0 Flash Drive $40 bucks retail.
speeds are as follows, its not the smallest one out there too, are this normal speeds for small flash drive or there are better ones?
SSSMan
Ahahah that's a good 1 i did not think this companies would do something like this. However i cannot take apart as then i wont be able to return.
You think all companies do that or some indeed make mini flash drives?
xSneak
42
The speeds are average, but good for a 2.0 device.
Fastest usb drive i've had was sandisk extreme usb 3.0
shabby
45
That drive has some craptaculer reviews.
I have that one and its descent in speed, the locking doohickey on the other hand sucks balls. It works at the beginning then it starts jamming and then it breaks inside and the two pieces separate.
bgt
573
My USB3 stick(Sandisk 32Gb) is a tiny bit faster(and not so small):
VirtualLarry
56,578
10,215
Which stick is that, exactly? Specs look good, I might want to purchase a couple as Linux boot drives. (Specifically, the 4K R/W looks decent on those, surprisingly.)
