bradly1101
Despite reports of Z77 and Z87 owners having success with having the Intel 750 NVMe drive show up in their BIOS after some tweaks (I'm not sure it runs at its rated speed on these boards), I decided to not mess around with my RAID setup for my spindled disks and not surprisingly the 750 didn't show up in the BIOS of my X79 board where it does run at its fastest speed. So I just installed Windows on my existing SATA SSD and use the 750 for programs and some data.
It's really fast, but am I missing out on even greater speed by not having Windows on the fastest drive? I don't care about boot times (I rarely boot), but are there other calls out to Window's files during everyday use that would benefit from the greater bandwidth or is the bandwidth of a SATA III SSD enough?
Also to check this drive's temperature you have to run a command line utility that writes a log file with current, lowest and highest temps. Does anyone know if the highest and lowest values are for the life of the drive or for a set time relative to when the utility is run? I couldn't find anything on this.
