- Jan 12, 2005
- 9,500
- 6
- 81
I apologize if there's already a thread on this 4 1/2 month old result, but I seemed to have missed this news when it originally came out. Turns out that those so-called "superluminal neutrinos" appear to be every bit as real as - yuk, yuk - God or the devil:
http://press.web.cern.ch/press/PressReleases/Releases2011/PR19.11E.html
23 February, 2012:
16 March 2012
8 June 2012
Einstein: A lack of change you can believe in.
23 February, 2012:
The OPERA collaboration has informed its funding agencies and host laboratories that it has identified two possible effects that could have an influence on its neutrino timing measurement. These both require further tests with a short pulsed beam. If confirmed, one would increase the size of the measured effect, the other would diminish it. The first possible effect concerns an oscillator used to provide the time stamps for GPS synchronizations. It could have led to an overestimate of the neutrino's time of flight. The second concerns the optical fibre connector that brings the external GPS signal to the OPERA master clock, which may not have been functioning correctly when the measurements were taken. If this is the case, it could have led to an underestimate of the time of flight of the neutrinos. The potential extent of these two effects is being studied by the OPERA collaboration. New measurements with short pulsed beams are scheduled for May.
16 March 2012
ICARUS experiment at Gran Sasso laboratory reports new measurement of neutrino time of flight consistent with the speed of light
The ICARUS experiment at the Italian Gran Sasso laboratory has today reported a new measurement of the time of flight of neutrinos from CERN to Gran Sasso. The ICARUS measurement, using last years short pulsed beam from CERN, indicates that the neutrinos do not exceed the speed of light on their journey between the two laboratories. This is at odds with the initial measurement reported by OPERA last September.
"The evidence is beginning to point towards the OPERA result being an artefact of the measurement," said CERN Research Director Sergio Bertolucci, "but it's important to be rigorous, and the Gran Sasso experiments, BOREXINO, ICARUS, LVD and OPERA will be making new measurements with pulsed beams from CERN in May to give us the final verdict. In addition, cross-checks are underway at Gran Sasso to compare the timings of cosmic ray particles between the two experiments, OPERA and LVD. Whatever the result, the OPERA experiment has behaved with perfect scientific integrity in opening their measurement to broad scrutiny, and inviting independent measurements. This is how science works."
The ICARUS experiment has independent timing from OPERA and measured seven neutrinos in the beam from CERN last year. These all arrived in a time consistent with the speed of light.
"The ICARUS experiment has provided an important cross check of the anomalous result reports from OPERA last year," said Carlo Rubbia, Nobel Prize winner and spokesperson of the ICARUS experiment. "ICARUS measures the neutrino's velocity to be no faster than the speed of light. These are difficult and sensitive measurements to make and they underline the importance of the scientific process. The ICARUS Liquid Argon Time Projection Chamber is a novel detector which allows an accurate reconstruction of the neutrino interactions comparable with the old bubble chambers with fully electronics acquisition systems. The fast associated scintillation pulse provides the precise timing of each event, and has been exploited for the neutrino time-of-flight measurement. This technique is now recognized world wide as the most appropriate for future large volume neutrino detectors.
8 June 2012
Neutrinos sent from CERN to Gran Sasso respect the cosmic speed limit
At the 25th International Conference on Neutrino Physics and Astrophysics in Kyoto today, CERN Research Director Sergio Bertolucci presented results on the time of flight of neutrinos from CERN to the INFN Gran Sasso Laboratory on behalf of four experiments situated at Gran Sasso. The four, Borexino, ICARUS, LVD and OPERA all measure a neutrino time of flight consistent with the speed of light. This is at odds with a measurement that the OPERA collaboration put up for scrutiny last September, indicating that the original OPERA measurement can be attributed to a faulty element of the experiments fibre optic timing system.
Although this result isnt as exciting as some would have liked, said Bertolucci, it is what we all expected deep down. The story captured the public imagination, and has given people the opportunity to see the scientific method in action an unexpected result was put up for scrutiny, thoroughly investigated and resolved in part thanks to collaboration between normally competing experiments. Thats how science moves forward.
