fast writes problem PLEASE HELP ASAP
BoomAM
4,546
Hi,
I just brought a new Creative Ti200 to replace my Creative GTS, but i have a few problems.
I can't enable fast writes. i`ve tryed everything and nothing works(the *.reg files off GeforceFAQ as well). I could enable it with the GTS card card, so why not the Ti200?
for some reason, utilites like RivaTuner and GTU says that theres no 3D card installed!!!
I am using Creative drivers 21.85. the nvidia reference drivers always screw up my system for some reason.
I also run WINXP Pro
how much more 3d marks will fast writes give me?:confused:
Rand
11,071
Your better off leaving it disabled anyways. It doesnt really give any gain in performance at all, and it often negatively impacts stability and potential overclockability.
Many manufacturers have taken to disabling it in the graphics cards BIOS to ensure it's not used.
sirsleepsalot
228
Like Rand said, don't worry about it... Mine are also disabled through the cards BIOS, there's nothing much you can do about it other than program yourself a new BIOS... :p
Rand
11,071
Well there is a BIOS editor you can get but I'd be reluctant to enable it personally.
