FarCry "Press USE key to insert card key"?
Expandable
I searched but nothing came up.
Just download Farcry Demo and ran into problem when message came up.
"Press USE key to insert card key". What is "USE" key?. I pressed all keys on keyboard but no help.
Many thanks.
mechBgon
Oct 31, 1999
30,699
Go into Options > Controls and set a key to the USE function, perhaps. I don't recall what the default is, but you can choose what you want. Does your character actually *have* the key card so he can use it?
Navid
5,053
You have to find the key card first. I think it is in the cabin on the hill.
If you have picked up the card, when you go to the door in the cave, when you get the message that you have to insert the card, press the use key.
Expandable
Thanks a bunch guys. I got it. It was an "f" key. I try all keys last night but some how I missed the 'f' key.
JBT
12,094
hmm never heard of somone not knowing where the use key is before. I have heard plenty of where is the "any" key though.
