FAR - USB Wireless G Adapter - FS
Status
Not open for further replies.
chemish
Newegg has the ENCORE ENUWI-G2 Wireless Adapter 802.11b/g USB 2.0 again for $10 with a $10 rebate and free shipping. I got a couple of these a few months ago when they did it last time and these adapters are nothing to brag about but they work fine and I had no problems with the rebate process. They are kind of large and can block other usb ports so be aware of that.
Last time I was able to use fatwallet so you can try going through them first if you want to try and get that 1% back as well.
http://www.newegg.com/Product/Produc...82E16833180017
Limit 2.
Rebate good 9/19 - 9/25.
basic wifi b/g/n 2.4ghz USB nubs can be had on ebay for just under 4 bucks if you are looking for the cheapest way to add wifi to something. I have one and it works well.
Status
