Far Cry water textures all screwed up?
Dolemite69
740
I tried loading Far Cry to see how it performed with my new evga 7900GTO, and I had all the settings maxed out and things were running smooth, but the water looked horrible? Any ideas on why that would be? Also, what is the stock setting for the 7900GTO? I just tried using coolbits on mine last night and it wouldn't go much higher than stock at all. Maybe 10 extra Mhz?
LittleNemoNES
4,142
Are you using the latest patch? Or is it the demo? The Demo doesn't recognize newer cards.
BTW, newest Far Cry Patch is 1.4.
Latest Nvidia Drivers are 91.47
Uninstall your old drivers and reboot before installing the new ones.
SonicIce
4,771
An eVGA 7900GTO is basically a refurbished 7900GTX. one that didn't make they cut. they're proably also getting rid of 7900 stock for g80
BFG10K
22,709
3,003
You must patch the game to the latest version.
Also set water quality to "ultra".
josh6079
3,261
What happened to the 1.33 patch? Can you not use that instead of the 1.4 anymore?
LittleNemoNES
4,142
:laugh:
Why wouldn't you want 1.4? :p Our point is that his game is obviously vanilla. I believe that there were compat probs with the geforce 6x< and other cards.
SonicIce
4,771
http://patches.ubi.com/far_cry/
1.4 adds a couple problems of its own, I dont remember specifically what though. It's all just multiplayer changes anyway. Most of the server are still running 1.33.
If you want 1.33 then the order is: Retail -> v1.3 -> v1.31 -> v1.33
Dolemite69
740
I'm not doing any multiplayer at the moment. It was definately the patch, as i had the water set to ultra before. The patch fixed it, and the water now looks silky smoove again. Thanks!
Woofmeister
1,385
Oh Lord, not Again! For the last time, the 7900GTO is not a refurbished 7900GTX!
