Far Cry... HeLp!!
bjc112
Hey all,
I don't know if i am obvisouly missing something, or just stupid....
I am in the Control mission in far cry.. All the heavily armmed guards and tons of climbing through vents.. 🙂
I have gotten through all the steam and got all the trigons..
I am at the part where it says " Get out of the building "
Come through the save point, shoot the guard quickly and then thats it. It's dead ends, all leading to somewhere I have already been... :|
Do i retrace all the way to the entrance or what??
I think im just overlooking something!!
Help!
Looks to be number 9 for me...
Pciture of a Door..
Warcrow this is "offtopic" 😉
Maybe ill slip through...
The save game pic shows a door with a blast mark on it? If so there should be a door just to the right of that one. Have you seens signs pointing the way for the Kitchen and WC (WATER Closet -- bathroom)?
You previously took a down elevator where in the middle of the room you can see large fans on the ceiling and floor, right? You could see a door directly across from the elevator, and there's a door on the right wall? From the elevator you took the (double) doors on the right which emptied out to a large lab?
Rcoky..
The part where i saved, ( the door i enter ) leads to the place with huge fans on the ceiling and floor, elevator directly ahead..
Well ill be damned..
It was right in the backside of the lab..
Thanks Rock.. I was running in circles having no idea where to go.
From your description, there should be a door on the left wall which leads to a lab. Actually double doors, a short hallway and a door which opens to the lab itself, correct? As you open that second door you should see another door in front of you across the room. If you open that door you should see a blasted door --> and then refer to my last post.
edit: Figured that you were on the catwalk near the back end of that lab. You're welcome and have some BigBoy fun!
