Fanspeed controller for CPU fan?
unholy414
110
I've been searching for a good fan speed controller but all I can find are ones designed for case fans. I've got this Vantec Aeroflow, which is a great CPU fan, but omfg, after like 3 years it's time to do something about it.
So can you guys recommend a good CPU fan controller? Don't care about price or if it doubles as a case fan controller, I JUST NEED SOMETHING TO STOP THE NOISE!!
-thanks
RallyMaster
5,581
Try and get a new CPU HSF. Vantecs are known for being loud (especially the Tornado). The better quality fan controllers will cost you more than getting a decent heatsink and fan. What kind of CPU are you on?
Mik3y
Banned
Mar 2, 2004
7,089
-thanks
case fans and cpu fans are the same thing. they're both fans. any controller should work fine.
RallyMaster
5,581
For my old computer, I'm planning to get a fan adapter on the Volcano 10+ and change that Thermaltake 60 mm to a Cooler Master 80 mm. My parents are using my old AXP2400+ these days and I would like to do them a favor by eliminating a main source of noise on that thing. If the fan reduces noise and I find out that cheapo 350W PSU is the only main noise producer in the case, I'm going to get them a new power supply.
Another way to reduce noise is to get a fan adapter. Larger fans = more air and usually less noise.
