socalcyclist
I have an Aspire X-plorer case that came with (2) 80mm blue LED fans. One was installed on the very back and the other on the top. I think they're both pushing air out as the exhaust but I'm not completely sure because it feels as air is coming both in and out of these two. Both are turning/fins-facing in the same direction as the heat sink fan and the mobo fan. I also installed two more 80mm blue LED fans on the front of the case, both mounted as the other two so turning the same direction. So, after reading some posts about cooling I believe I'm supposed to have intake on the front and exhaust on the back but I think they're all installed as exhaust. Can somebody please shed some light on this poor fool who knows not what he's doing. 🙂
Also, here are some stats with temps from SiSandra. The first set was taken at idle. The second set was taken after running 3dmark2001 benchmark. Are those temps ok? (board maxed at 49 and the CPU at 43)
Date & Time : Sunday, April 09, 2006 2:13:16 PM
Board Temperature : 45.0°C (Min 45.0°C; Avg 45.0°C; Max 45.0°C)
CPU Temperature : 38.0°C (Min 38.0°C; Avg 38.0°C; Max 38.0°C)
Power / Aux Temperature : 31.0°C (Min 31.0°C; Avg 31.0°C; Max 31.0°C)
Chassis Fan Speed : 1875rpm (Min 1875rpm; Avg 1875rpm; Max 1875rpm)
CPU Fan Speed : 4963rpm (Min 4963rpm; Avg 4963rpm; Max 4963rpm)
CPU Voltage : 1.34V (Min 1.34V; Avg 1.34V; Max 1.34V)
Aux Voltage : 2.61V (Min 2.61V; Avg 2.61V; Max 2.61V)
+3.3V Voltage : 3.34V (Min 3.34V; Avg 3.34V; Max 3.34V)
+5V Voltage : 5.13V (Min 5.13V; Avg 5.13V; Max 5.13V)
+12V Voltage : 11.43V (Min 11.43V; Avg 11.43V; Max 11.43V)
Standby Voltage : 5.12V (Min 5.12V; Avg 5.12V; Max 5.12V)
Battery Voltage : 2.94V (Min 2.94V; Avg 2.94V; Max 2.94V)
CPU Core Power : 56W (Min 56W; Avg 56W; Max 56W)
Date & Time : Sunday, April 09, 2006 3:50:44 PM
Board Temperature : 47.0°C (Min 45.0°C; Avg 45.9°C; Max 49.0°C)
CPU Temperature : 40.5°C (Min 39.0°C; Avg 39.4°C; Max 43.0°C)
Power / Aux Temperature : 31.0°C (Min 29.0°C; Avg 29.6°C; Max 31.0°C)
Chassis Fan Speed : 1875rpm (Min 1834rpm; Avg 1874rpm; Max 1918rpm)
CPU Fan Speed : 4963rpm (Min 4688rpm; Avg 4962rpm; Max 5273rpm)
CPU Voltage : 1.34V (Min 1.34V; Avg 1.35V; Max 1.36V)
Aux Voltage : 2.61V (Min 2.59V; Avg 2.61V; Max 2.62V)
+3.3V Voltage : 3.33V (Min 3.28V; Avg 3.33V; Max 3.34V)
+12V Voltage : 11.37V (Min 11.31V; Avg 11.38V; Max 11.43V)
Battery Voltage : 2.94V (Min 2.85V; Avg 2.94V; Max 2.94V)
CPU Core Power : 56W (Min 56W; Avg 56W; Max 57W)
