What are some good 120mm and 92mm case fans(i dont want any fans with lights) I have a Chenbro Gaming Bomb 2 and have a 120 mm fan in the front and back and a top 92mm fan. What are some good fands that move alot of air?
I have 3 Scythe S-FLEX fans in my case (Newegg sells em for $14.99). There are three different ones: 800RPM, 1200RPM, and 1600RPM. I have a 1600RPM on my top blowhole and a 1200RPM as an intake over the HDDs and another 1200RPM exhaust out the back. They are so quiet. I can hear my CPU fan, which can get loud when under load, over all of them.
EDIT: To add that they have great airflow (49CFM for the 1200s, 63.7CFM for the 1600) and my system temps maintain around the mid 40s.
