fans causing power problems?
ku
1,309
ok,, so here is the deal,,, I am planning to get a enlight 300w p/s.. I am planing to run 5 case fans... these are 3 80mm fans (2 of them aew 2.1w, third is a generic fan that i dont know specs about ( too lazy to remove and look at it heh..),, and 2 pci slot fans. I am running a 1.4ghz athlon tbird with sk-6 w/ delta fan, 8xdvd, 16xcd-rw, 80gb 7200rpm, 512mb ddr, gf2 64 pro.
Okay, so i am currently running on a generic 300w supply with no problems with everything there but only (1) pci slot fan and (1) 80mm fan. will adding those few fans cause me problems? i highly doubt this but i am bored and i feel like asking.
Swanny
7,456
You might want to step that PS up to an Antec or something just on general principles of stability.
0beron
758
My 300W no namer started acting up when I put 4x80mm fans in so you might need to get something more powerful. I say try it out. If there are stability problems after just adding the fans, it is most likely the power supply and you need to get something more powerful. I opted for the 431W Enermax, no power problems now.
