Ok. I thought a fan was a fan but now there are many types of fans ?
Can someone explain the difference between 4 pin fan, 3 pin fan and smart fans?
Also, if you plug the fan into the motherboard does the power come from the motherboard or do you still plug the fan into the psu (in addition to the mb). If you plug it into both places then why do mb have specs that indicte the fan can only draw xxx amps ?
