FANS-120mm
reddog3941
24
hey all,
just purchased a antec slk3700amb case with a 120mm fan in the back, the ? is do i need a front fan! my system specs... mobo asus a7n8x, cpu amd 2800/333, corsair 512mb pc2700 and the hard drive is ?
Gravity
5,685
I thought that came with a front fan. I just opened a Sonata and it has two 120s but the front one is slightly hidden. Nice case, huh?
Sid59
11,879
your sonata came with 2 x 120s .. i got ripped .. i had top pay for the front 120.
reddog3941
24
hey gravity,
i guess the sonatra is a little differ. but a sweet case. i have a 120mm placin for the fan up front, but... not included. i almost bought the sonatra, but could'nt pass the deal on this case.
Gravity
5,685
I super impressed with that case. I'll trade my Thermaltake Xaser II for it any day!!
Sarobi
94
Originally posted by: reddog3941
hey all,
Yeah, I would put a fan in the front. Get a nice quiet one --- unless you are overclocking, you won't need one w/ really high cfm so you can get one that's practically silent.
Goatsan
123
i have a 3700amb also, and i put a 120 fan in the front (it didn't come with one). i suggest also cutting off the pre fab grills they have on, they seem to me that they block to much air flow, and antec fixed it on their 3700bqe.
reddog3941
24
hey G-man,
what kinda fan did u get for the front(120mm-make) and the grills in the front inside and or back?both?thanks!
ski2slow
244
I just bought Antec SLK3700BQE with Papst 4412FGL as my front fan. This 119x119x25mm Papst fan is supposed to be very quiet. The BQE case will not fit a 38mm thick fan in the front. I'll probably replace the Antec fan with this as well to make my PC quieter.
Goatsan
123
reddog, for the front, i just picked some random one off a site, it didn't matter that much to me at the time. and i didn't put a grill on the front, since the front part is covered anyways. as far as a the back goes, i just made one from the scrap metal i had when i cut out a window from the side.
