Originally posted by: Scoop
I don't think there's any fanless GPUs of that caliber.
I think one of the fastest available stock fanless card is the BFG 9800 GT passive (it comes with a Thermalright heatsink). It CANNOT run with no airflow as it depends on case fans moving at least a little bit of air.
I used to run an 8800 GT with an Arctic Cooling Accelero S1 and it also CANNOT run with no airflow.
Both can run with no fan on the cooler, but both need case fans.
Radeon 4850 can run with the Accelero S1 if there is airflow.
Originally posted by: bloodandsoil
I'm researching building a PC that has no moving parts. I'm asking for recommendations for fanless zero decibal power supplies that have enough watts to support a low-end video card (like an Radeon 4850), an SSD storage drive, ATX motherboard. That's about it.
G'luck on that. It is reasonably easy to build a "quiet" system, but exceedingly difficult to build a "silent" system. You can put the biggest heatsink that will fit on your CPU and GPU, and if your case is closed and you don't have any fans in the case then if you are running a Radeon 4850 and your E6600 you will experience overheating issues.
Oh yeah, once you get rid of fan/motor noises, you'll start to hear humming and whining from the PSU, graphics card and motherboard (if ambient noises are low enough and your hearing good enough).
My personal best effort was having a PSU fan and one undervolted 120mm case fan. I have a passive Antec Phantom 350W PSU in my garage. It is now dead, likely from a combination of bad caps and heat.
Directron has a whole
section dedicated to fanless/noiseless PSUs.
