Recently I upgraded our HTPC and had to get a new power supply, but I foolishly went cheap and no longer have a silent HTPC.
I have seen fanless PSU's before, but this case (Corsair 330R- I know it's big but I needed a totally neutral [with the ports covered], monolithic speaker stand) has too many filtered vents to have much positive pressure, so I wonder if a fanless PSU would get enough air.
And now that the power supplies go on the bottom I have to flip them so they aren't trying to get air through the carpet. In this orientation wouldn't its hot air just make the case get hot?
It's not a super low powered system. It runs at its minimum clock speed (1.6Ghz) 98% of the time but can ramp up to its stock 2.66Ghz if it's doing a bunch of HD recordings, playing another and streaming (out) at 720P, whch rarely happens.
So I don't need more than 400W. Given the above conditions, do you think this is a workable solution? Are there any with fans that you know to be silent with moderate loads?
