- Jun 3, 2005
- 23
- 0
- 0
I am building a fanless mini-itx pc with HD-Plex H3 box. I was wondering which mini itx board I should go with. The pc will be for everyday use, limited gaming (angry birds, bejeweled type stuff), moderate to heavy photoshop and adobe premier use. Will also be using it a secondary blu-ray movie player. I plan to use a vertex 3 or equivalent SSD and 8gb memory.
I narrowed it down to INTEL 61 or 67 chipsets... wondering if there are strong opinions one way or the other. I am NOT married to the intel choice, i.e., if there are better choice on the AMD side, I am open to it.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115075
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
