Question Fanless CPU cooler for LGA 775?
Kledgie
190
31
What is the best bet for fanless cpu cooling on my 775 board? My CPU only pulls 20 watts. If anyone could link me a heatsink or any other option, plz do.
aigomorla
21,108
3,631
A Thermalright HR-02 would be my first pick Its big tho, so i would only get it if your case has a 120mm rear exhaust.
These guys can most likely be run passive @ 20W, and if you have a exhaust or any air movement in the rear even better.
They have a wide fin spacing which was designed for that.
Another is the Nofan but its very pricey.
Are you going for a complete passive build?
Even adding a low spin fan in the rear exhaust will help immensely, and not generate a lot noise.
Kledgie
190
31
Thx for the recommendations. A little out of my price range tho. I was hoping for something cheaper. What low spin fan would you recommend for the rear exhaust?
aigomorla
21,108
3,631
What is your price range?
The thing about passive is they require mass.
Mass = $$$
As for fan selection, these guys are great, IMO the best value for performance / noise:
These guys are the gold standard for noise / performance.
The grey noctua is basically the bulk version of the brown/tan, in a cheaper retail box with less accessories, hence the difference in price.
