herbiehancock
I'd like to put a front panel fan and temp monitor and controller in my pc.
Just wondering if anyone uses one and what you'd recommend.
I've looked at the Lian Li TR-3A and the Logisys FP206SL.....both of which seem to be exactly the same...same readouts on the panel, same buttons and locations, etc.
Looked at the CoolerMaster Aerogate 3.....
Looked at the SilverStone FP52 Eudemon...
And have considered the Aerocool GateWatch 2...........
Maybe even the Sunbeam Chromatic Windmill..........
I am just completely confused and befuddled............
But, my requirements are it has to monitor at least 3 fans and temps, four is better. It has to be in silver (gotta match what I got, ya know...), and it doesn't have to have a bunch of other junk like card readers or USB ports....Lord knows I've got more of those than I use already.
So, those that have used some, any, one of these contraptions, what works, what doesn't, and what to avoid and what to consider.
Thanks!!!
Thanks!!!
