Fan Surges...
Meractik
1,752
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7200803
I bought this case 3-4 years ago and I am still using the default PSU that came with it. I do not put the PSU under any extraordinary excessive load I just do day-to-day office tasks but lately I am noticing reving noises coming from the PSU upon boot for about 5-10 min. Then they go away and the system runs as normal.
I have dusted the case/PSU several times with canned air to push out all dust and stuff from the fan but I still get this revving sound each and everytime the PC is either awoken from a suspended/sleeping status or turned on from being shutdown. Which lasts for 5-10min each time until eventually it goes away...
Is this normal for PSU's now-a-days? to rev up and then rev down?
I never noticed the PSU doing this at any other time until recently having had the same PSU since its build and no other system changes done to the PC.
I do have a replacement PSU I bought when it was a good deal which is a 550W (which is probably way to much for my needs, but was a good deal so I bought it..)
Should I wait until this one dies? is there harm to my system by holding out? or should I replace now?
Before anyone says anything I did open the case and it is indeed the PSU Fan that is reving and not another fan, as mentioned above though it does go away eventually (after 5-10min).
Thoughts?
TemjinGold
3,050
65
Definitely don't wait until it dies. If it's a crap PSU, it'll damage other stuff when it does.
blastingcap
6,654
If PSU is overheating it may spur the fan to rev up. The fan itself may be faulty. In either case, that is a crap PSU and I would upgrade it ASAP. Since you have a 550W replacement, assuming it's any good, use that instead. Don't wait. A bad PSU can damage everything else in the case.
Meractik
1,752
good to know, ill plan to perform the swap out with the replacement PSU later today. :)
Meractik
1,752
What are your impressions on a Rosewill Capstone 80 Plus gold 550W Modular PSU? It was on sale for $90 and states its got a 5 year warantee.....?
Cerb
17,484
33
86
That's a good PSU.
...at a fair price. Rosewill might not be your #1 PSU brand, but they are just rebranding a really good Super Flower PSU. Go for it, before the modular version stops being on sale, or you start thinking a cheaper PSU would be just as good :p.
Torn Mind
12,086
2,774
Diablotek's garbage and others of its ilk, such as many Raidmax, Logisys, and Coolmax PSUs, are PSUs that will destroy your computer along with it, probably through a huge surge in its final breaths. Unintended user-induced destruction occurs with these units because users expect them to meet their rated specs, and they absolutely do not.
Meractik
1,752
Well that is good to hear its a good PSU, I saw some good reviews for it when It went on sale and its the one I purchased, just have yet to install it. its just sitting in the corner of the room still unopened - had it for like two months now...
