i am looking for pci slot fan, as quiet as possible to move air from outside to inside and also an 3.5" bay fan thing if it exists, let's hear from fellow forum users 🙂
You could always rig up a regular case fan on the back that sucked through empty slots. Or you could cut off the "bars" if you think you don't need them anymore.
If you have three (3) available 5.25" bays you can get a Scythe KAMA BAY in Silver, Black, or White. Directron has both Silver and Black on sale right now for $17.99. The going rate seems to be $19.99.
I don't have one so I can't comment on how well they work or how quiet they are, but according to some of the reviews I've seen the KAMA BAY works well and is quite quiet. I think it would look pretty cool in one of the Lian Li V-Series. I'd get one if I had one more free 5.25" bay.
