Just make a note to yourself that 4400RPM is 100%. Problem solved.
"More power, Scotty!!!"
4400RPM isn't 100%... the computer told me so.... ^_^
computer says yes...😛,on a serious note how does 85% sound?,wont 100% be deafening?,not sure why you cant btw.
With my EVGA 560ti (rig in sig) using EVGA Precision X my GPU fan speed is capped at 85% @ 4400RPM... why? Why can't I or why won't it run it at 100% ? 😕
Have fun burning out the fan on your card
Seriously though, I think Precision X is misreporting the fan speed
Why on gods green earth would anyone now a days want to ramp their gpu fan to 100%?
The fan is presumably temp controlled, so if the rest of your system is keeping the GPU cool enough that it only needs to run its own fan at 85% speed to stay in the correct temp range, then that's how fast it'll run.
Run the test again in July and see what happens. 🙂
I'm curious as to why I can't even manually take it to 100%, or automatically
My first thought was, why in gods name would anyone want their GPU fan at even 85%?..... I dont know video cards you people run but in my experience, anything over like 60% or so is usually pretty god damn loud. I run my card at lowest possible always unless under load.
If I had my card running at 100%, you could probably hear it from 2 rooms away in my house.....
It sounds like a supercharger on a V-8 Chevrolet (minus the exhaust note.)
No, I'm just trying to understand the software and my card's capabilities better. Running 3DMark puts it at 85% with nowhere else to go...
My GPU idles at 33C @ 40% fan, hits 85% fan @ 60C and tops out at 66C in 3DMark.
Maximum GPU Temperature (in C) 99 C
