- Nov 26, 2005
- 15,197
- 403
- 126
EDIT:
First off if you are using a gigabyte board you MUST flash your bios to the newest bios available. Than just follow these simple steps.
Make sure windows is set to show hidden files.
First Enable Overdrive in the Catalyst Control Center.
Next Create a new Profile using the Profiles Manager in the CCC and make sure Save All Catalyst Control Center Settings is checked.
For Vista 32/64
Then go to the following location and open the following file for editing "C:\Users\Your Windows ID\AppData\Local\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
For XP 32/64
Then go to the following location and open the following file for editing "C:\Documents and Settings\Your Windows ID\Local Settings\Application Data\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
Now go down the page until you see the following lines in the XML file ...
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Automatic" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="23" />
Change the "Property name="FanSpeedAlgorithm" value=" from "Automatic" to "Manual"
Then change "Property name="Want" value=" from "23" to your desired fan speed.
Save the file, then reload the Profile you just edited in the CCC. Done.
Copied and Pasted from UT3 forums, Enjoy
