fan speed control
sambao21
How does this sound? Will this be a good match up for a vantec tornado and a slk800?
[L=]http://www.kdcomputers.com/eui/prime/profile/724/29/component.htm[/L]
Also what about the thermaltake A1295 [S=]http://www.thermaltake.com/products/accessories/switch.htm[/S] Can it handle a Sunon(Vantec) tornado?
I didn't check out your links but I can tell you, unless your computer is in the other room, don't buy the tornado! I had it on 5V, that's right, only 5 volts and it still drove me crazy.
using a ystech 48cfm now, much better(on 7 volts)
your link
your link #2
well, I can tell you that the first link, from KDC will not work on a tornado. tornado is rated at around .7 - .8 Amp. that thing goes up to 500mA. the second link, TT doesnt' mention power ratings, might want to email them and double check before you buy. it's one powerful fan.
