- Sep 28, 2001
- 8,464
- 155
- 106
from a posting:
You can control the speed with a utility like SpeedFan without having the speed-monitoring feature: selecting a fan speed of 60% at a certain temperature level and range controls the fan according to pulse-width-modulation, and the "control" does not utilize the fan-speed monitoring in any way.
I am getting a dfi lanparty ut nf4...and i might sound moronic...i KNOW that there are several connectors, CPUFAN, CHASFAN1, CHASFAN2 etc.... and those support speed monitoring since they have the SENSE connector.
But i really am clueless (and i didnt see any information) whether its actually possible to adjust the speed of the fans itself via the mainboard/software. (With fans plugged in the approptriate connectors).
SO...the above posting suggests that a tool liek speedfan can actually actively SET/ADJUST the fan speeds ? I always thought for speed control i need a special fan-control module etc.
Please someone enlighten me. How do i know which boards/sensors actually support the adjustment of the speeds ?
Btw. i will build with a XP-120 w/ variable Enermax 120mm.
Addendum: In case you wonder...maybe my question is not THAT pathetic. if it were that easy that everyone can easily adjust speeds with software...why then use people stuff like 12V-->7V converters and/or special fan controls w/ thermal sensors ?
Thanks a lot !
Thanks a lot !
