Has anyone noticed that manfs. fan specs are wrong ? w/ relation to noise
I read a fan comparison on directron.com site and all the 80mm fans were way past their spec on noise levels.
http://www.directron.com/noise.html
All I want is accurate info, how are manfs measuring their db ratings ?
I have 3 Everflow 80mm fans in my case (39cfm/26db) & was thinking of replacing them w/ panaflow L1 fans (24cfm/21db) but based on directrons tests, why bother ?
I now will try to stick to low rpm 120mm fans if possible. ie Vantec Stealth (53cfm/28db) & JMC J120L (61cfm/26db).
Regards,
Jose
Regards,
Jose
