- Mar 15, 2014
- 359
- 50
- 91
With my latest build I'm currently looking at fans, deciding what to buy. There's an aesthetic element involved but I'm most interested in performance.
I'm actually making a comparison chart of all potential 120mm and 140mm fans.
Except for Akasa few fan suppliers seem to provide noise level dB(A) figures for the range of speeds the fan supports. The figures all appear to be single figure dB(A) and CFM ratings at max RPM.
In my primary PC I have Akasa Viper 120mm CPU cooler and case fans capable of 1900 RPM, used along with a couple of 140mm (1600 RPM) case ones. I have the BIOS set to use 75% PWM on all of them and even under heavy load in the height of summer, it rarely reports four figure speeds. Even when it does they're kicking in temporarily to get the temperature down and go nowhere near their 1900 RPM max speed.
So the question: is it fair to judge a 1900 RPM fan like the Akasa Viper 120mm whose published figure is 28.9dB(A) at max speed when it is being used more typically at half that speed?
At the slowest speed supported, 600 RPM the figure quoted is 6.9dB(A).
I realise the relationship between fan speed and noise level is not linear, the figures for the Viper show that clearly but let's assume it is.
Averaging the Akasa Viper figures out using the lowest and highest numbers at 1000 RPM around 44 CFM/13dB(A) as the more typical airflow/noise level.
If you look at the Noctua NF-F12 with its stated 1500 RPM max/55 CFM/22.4dB(A) and do a quick, again linear, comparison with the Akasa Viper at 1500 RPM the Akasa appears significantly better at 66 CFM/17.68dB(A).
The better spec Noctua NF-A12 figures using the same criteria are 45CFM/16.95dB(A) ie. near enough the same noise level but 30% less airflow.
At 1000 RPM the NF-A12 beats the Akasa Viper on noise at 11dB(A) so it is quieter but again the, roughly calculated, airflow at that speed is 30 CFM, 33% less.
Of course this all relies on manufacturers' figures being trustworthy. If you accept they are: surely just comparing fan dB(A) and CFM at max speed is not like for like and therefore useless to potential customers. Wouldn't both max and min CFM/dB(A) figures be more helpful? Why not a mid-range figure like 1000 RPM (for 120mm fans) too?
