Hello all,
My Lian Li PC-68 case comes with an 80mm CPU exhaust fan. The fan is very loud and is nearing the end of its life.
I would like to replace it with a quiet Panflow 92mm or 120mm unit. However, I was worried that using a fan adapter would cause turbulence within the adapter, canceling any reduction in noise a larger fan has to offer.
Have any of you successfully used an adapter kit? If so, was the fan any louder? Did you use the adapter before the fan (sucking air in) or after the fan (exhausting air our)?
In specific, I was looking at this 80mm to 120mm adapter to connect up this Panflow 120mm L1A unit.
Thanks in advance...
