A little under a year ago I purchased two ARCTIC P12-120 mm Case Fans, Fan Speed: 1800 RPM , MODEL # ACFAN00118A
Today, I perceived a subtle, high pitch sound, which stopped when I disconnected both fans, but when either is connected by itself, it produces the noise.
A third fan, original with the computer, is three years older than the others, but creates no such sound.
Since both are creating the noise, is this just a coincidence, or could there be something else fan related? I dunno, like whistling thru a vent or something. Just guessing. All the vents are clean.
I liked these fans from the beginning, pretty quiet, but since they are both making noise after only a year, I'm thinking I need to replace with a different brand. Or is this just something one should expect from this example of type and value, particularly since that older fan has outlasted them.
I also noticed during preliminary fan shopping that some fans are described as drawing air in as well as pushing out. Are they talking about doing both at the same time or perhaps reversing the way it is mounted to created the desired effect?
