G Grendel99 Senior member Dec 12, 2000 888 0 0 Feb 21, 2001 #3 Any 80mm fan will do. Try a Sunon or YS Tech.
M mr_cheesy Senior member Oct 11, 1999 809 0 76 Feb 21, 2001 #4 i went with high output nidec 80mm. keeping me at 37c now. tried a standard sunon 92mm but it ended up being 5c warmer
L LIVAN Golden Member Oct 24, 2000 1,210 0 0 Feb 21, 2001 #5 The delta is a 60mm, woulkd those 80mm or 92 mm fit with the clip and everything?
A arod324 Golden Member Jan 21, 2001 1,182 0 0 Feb 21, 2001 #6 You can get a 60mm to 80mm or 92mm adapter. You can buy one from here.
M mr_cheesy Senior member Oct 11, 1999 809 0 76 Feb 21, 2001 #7 i just hooked the clips to the wire 80mm grill. actually it holds very well.
L LIVAN Golden Member Oct 24, 2000 1,210 0 0 Feb 21, 2001 #8 fan filters that is suppose to deaden sound. Those work at all?
