Fan replacement for ATI card
bengalih
I have an original ALL-IN-WONDER RADEON card (that's the full name), and the fan is bad on it...it's missing a fin and it's noisy.
ATI will not give me any info on replacing it without going through their whole RMA process. I'm sure they will charge me a ridiculous amount for a 50 cent part that I need and can swap myself.
Does anyone know where I can get a hold of a replacement fan? It doesn't seem to be standard fan, it's in a little recessed well and seems to have a magnetic core.
You might have to replace the entire cooling assembly on it. Not sure that the original AIW Radeon cooler looked like, but I'd try looking around at 3D Cool and FrozenCPU. If its just a smal HS and fan mounted over the GPU core, you could probably rig something up with a large ram sink or other heat sink matching the size of the core. I can't imagine the original AIW Radeon putting out the much heat.
