- May 13, 2003
- 13,704
- 7
- 81
I've putting off a mod on my server case for a while now, and I think I've found a decent solution to get it over with quick. The case has two banks of 4 92mm fans, which I have Akasa Amber 92mm fans installed. I think I'm gonna mod it to transfer the power over CAT5e cable. Currently it's modified (half way completed but stalled for 2 years now) to use a DB 9 serial power for power to the fans. At this point, I just want to put in the fans and get them going.
I think this will work, as the fan power requirements aren't high, and it's easy to solder the connections necessary...
Thoughts?
Thoughts?
