YS TECH also makes a 120 mm fan that pushes 131 cfm. and the panaflow and sunons are only like 105 cfm. im guessing this is considerably louder then the other 2?
ok now that i know what fans are the good ones i have a queston. i plan on puttin 1 in the side and 1 top blowhole. and im wounderin is it better to have the side one blowin in and the top blowin out or have the top pullin in good air and the side blowin out. or both in or both out?
I already have a 120mm pabat blowin in from the front and a 80mm blowin out the back and a 80 mm side blowin in above the CPU. it came with my case. it might come out when i put the 120 in dont know yet. im just wounderin what the best way to place them to get the most efficient cooling.
also i plan on cutting these witha hole saw but do they make them big enuff for a 120 mm fan? if so i use one thats a little smaller then 120 mm right? if they dont have them that big what other then a dremel can i use? i dont have a dremel
 Facebook
Facebook Twitter
Twitter
