- Aug 16, 2008
- 86
- 0
- 0
Here are the components:
CASE = CM590
MB = ASUS P5Q-E
CPU = Intel Q9550
CPU HSF = ARCTIC COOLING Freezer 7 Pro 92mm
GPU = 2 Sapphire 100237L Radeon HD 3650's
Mem = 2x2GB DDR2-800 Mushkin
HD = 2 x WD 640gb hard drives
PSU = CORSAIR 550VX
OTHER = TEAC Floppy drive; Possibly 1 internal DVD-RW
Usage:
-No games or OC'ing
-Home video editing
-Trade for a living across 3 LCD's
-Basic web/email/etc.
I'm getting the CM590, comes w/ 1 front, 1 rear 120mm. Has 2 sides, 2 tops, and 1 more front if desired. I've read positive pressure is best.
Questions:
-Top fan(s) should be exhaust, right?
-Side fan(s), intake or exhaust?
-Overall, better to have more intake than exhaust to allow for positive pressure? If yes, should I cover the unused vent holes?
-Given my above components, any recommendations on how many/placement of fans for the CM590 I should have? I don't need overkill. Prefer quiet over super-cooling.
Fan Controller:
-Does the CPU fan (ARCTIC COOLING Freezer 7 Pro) also hook up to the fan controller, or just the case fans?
-The number of dials on a controller should be equal to the number of fans I have, right?
-The fan controller just plugs into the motherboard, and then I can just speed/slow the fans by turning the dials?
Tnx.
CASE = CM590
MB = ASUS P5Q-E
CPU = Intel Q9550
PSU = CORSAIR 550VX
Usage:
-No games or OC'ing
-Home video editing
Questions:
Fan Controller:
Tnx.
