i purchased a aspire turbo case, and it comes with a stock fan right on top of where the processor would be. the factory installed state had the fan blowing in instead of out, should i reverse it too get better cooling, right now my cpu idles at 47.
Well, none of us have your particular setup, so try it and let us know. Your temps seem just fine as they are, but they might improve by not having that side fan fighting your CPU fan. You could always eliminate one fan and build a duct!
