Fan Placement in TJ08-e?
Sleepingforest
I just got two Corsair SP120 Quiet Edition fans as a surprise (and late, I have some very distant relatives) stocking stuffer type present. Right now, all I have are the default fans that come with the 212 Evo and the TJ08-e: one Cooler Master 120mm fan and one Silverstone AP180 fan. I have room for 2 more fans: one on the CPU cooler (for push/pull instead of just pull) and one on the exhaust slot on the case.
With that in mind, how should I arrange the fans I have? I'm thinking of placing the Cooler Master fan as an exhaust and using the two Corsair fans for push/pull. Is there any way to connect both fans to the CPU fan header, or should I just use the system fan headers? The Sniper M3 has, I believe, 3 system fan headers and one CPU fan header. Should I get a splitter for the CPU fan header? If so, what would you recommend that I use?
Thanks for reading this. Every scrap of help is appreciated!
The Corsair fans would go great with the Hyper212 Evo. You could connect those 2 fans to CPU_FAN header with a 4 pin PWM Y-splitter fan cable or the more common 3 pin Y-splitter fan cable. The rear fan should be connected singly to the SYS_FAN header.
The Corsair fans are standard 3-pin so you don't really need a pwm splitter, a regular 3-pin y-splitter would do. For automatic control you will need to set the cpu fan to voltage control in the bios.
You could also do without a splitter and connect the second fan to a casefanheader and use Speedfan to control them.
